1992 ECU OBD1.
My grandfather has a 1992 2.6L Amigo and he has an 02 orange sensor light on by the dashboard. Quick question where is the dianostic receptor so I can use a jump wire and read the code or meaning of the 02 light.
Thanks.
o2 light is a maitaince light,to reset it you have to remove the instrument cluster.an look for the abreviation KSW theres a screw there on it,remove it an place the screw in the other KSW hole thats still open.thats the only way to reset the light.
Thank you for your quick response. I have to pull the instrument cluster and reset the KSW. Cake Walk!!![img]smileys/smiley2.gif[/img]
THanks, Frank
