stuck acclerator
Old Dec 29, 2005 | 06:30 AM
evos2k's Avatar
The gas pedal on my 94 Rodeo seems like there is a brick behind it when i gas it. Acceleration is also very slow and when I try and floor it, the pedal is stuck for 2-3 seconds. What could be causing this?
Old Dec 29, 2005 | 01:21 PM
THERE,S A RECALL ON THE CABLE STICKING,AT THE VERY TIP OF THE CABLE WHERE IT CONNECTS TO THROTTLE LINKAGE,YOU,LL PROABLY FIND THE RUBBER TIP THAT COVERS THE INSIDE OF THE CABLE ALL MELTED AWAY,OR GONE.THIS STICKY STUFF GETS PULLED INSIDE OF THE CABLE CAUSING IT TO BIND,CAN TRY CLEANING WITH CARB CLEANER IF WANT IT MAY HELP.BUT RUN IT UP TO YOUR DEALER AN SEE IF YOU CAN GET THE RECALL DONE,ALL IT IS ANOTHER RUBBER BOOT REPLACEMENT.IF THE CABLE CAN BE SAVED.THAT WONT MELT AWAY AGAIN........THIS RECALL ALSO EFFECTS THE OLDER TROOPPERS AROUND THE SAME YR RANGE.IF IT ISNT COVER JUST BUY THE KIT.CANT BE NO MORE THAN 2.00 OR 5.00 DOLLARS,OR REPLACE YOUR CABLE.
Old Dec 30, 2005 | 05:25 AM
evos2k's Avatar
Thanks! I'll try that
edl63
Apr 29, 2008 04:47 AM
s10lowrider
Dec 8, 2007 01:59 PM
tkinzer
Nov 24, 2007 08:34 PM
Boozer
Aug 30, 2007 11:24 AM
dutchie
Aug 22, 2007 07:17 PM
