Suspension Warning Light
Old Oct 9, 2010 | 10:53 AM
bls-fla's Avatar
Default Suspension Warning Light
I have a 2000 Rodeo LES 4WD with the Intelligent Suspension Control(ISC). I just finished replacing front wheel bearings and left front axle. Since completion, the ISC warning light comes on and stays on. I know the sensor on top of the shock is connected so I assume it has to do with replacing the axle. Is it just a matter of resetting the sensor and if so how do I do that?
Old Oct 17, 2010 | 12:19 AM
WestonZen's Avatar
I'm interested to see that answer,too. I had the same thing happen after I had some issues with my wheel bearings. The light came on and stayed on. And out of curiosity, have you checked your fuse for it? I haven't checked mine yet so that could be a place to start, I suppose.
Old Oct 17, 2010 | 06:39 AM
bls-fla's Avatar
Hello neighbor I'm in Delray. My issue also started with a bad wheel bearing; I ended up having to replace the axle as a result. I suspected that it was just a matter of resetting the sensor/indicator circuit but no one could tell me how to do it. So I ended up paying one of the online car experts. He told me that if the axle was removed the sensor would assume a problem and would trigger the warning light. However, he said only the dealer could reset the thing. I know everything is OK so I'm going to live with it until and if I have to go to the dealer for something else. If you learn something different please let me know.
Old Nov 11, 2010 | 01:29 AM
  #4
absentkn's Avatar
Sneaker News | LudaKicks | October 17, 2010 at 7:00 pm Last year, the Nike Air Max LeBron VII was abbreviatemed down and accustomed a Zoom Air sole just in time for Cakinand’s abbreviate pblow run. This year, Nike is giving the coolbrilliant a additional Air Max-abjectd archetypal abundant beforehand in the division. The LeBron 8 V2 Spec owns a feature Max Air sole and Flywire forth the abandon, agnate to the accepted Lebron 8. The capital aberration is the use of a cobweb-like actual inaccount of covering. This d5f8831507491c8c3106342dbb49023abroad relies on a atome base with red and atramentous emphasiss actualization thasperousout.Nike LeBron 8 V2 SpecWhite/Grey-Varsity Red Nike Zoom Lebron 5 V White Dark Navy Gold ShoesPost tags: LeBron 8, Lebron James, Nike, Nike Basketbrawl, Nike LeBron 8,Supra Low III, Nike LeBron 8 V2 Spec Tags: LeBron,http://www.lebron-james-shoes.org/, Nike,Supra Indy NS, Spec Tweet This Share on Facebook Digg This Save to adorable Stumble it RSS Feed Facebook Commentsrelated items: All Whites Home Kit 2010-11 New Zealand Kobe Bryant has new shoes for the 2008-09 NBA Season Nike Zoom Kobe IV (4) Air Jordan 3 Future Sole Melo M6 Release Details
Old May 20, 2012 | 02:39 PM
  #5
Windy's Avatar
Member
just to update the thread - anybody ever found out how to reset the ISC? tired of that mystery talk about "only the dealer can do it" - they are only humans as well, only difference they know how! Pass it on for crying out loud!
todenbach
Aug 11, 2015 05:32 PM
82imarkdiesel
I-Mark
Dec 4, 2012 12:58 AM
markeng
May 23, 2010 07:33 PM
kdfvwman
Oct 5, 2009 05:16 PM
driven505
Jan 6, 2009 11:17 AM
