Long crank when HOT only
Old 04-25-2015, 09:18 PM
Dr76's Avatar
Question Long crank when HOT only
'94 3.2L has a long crank, but only when HOT. Always cranks and starts fine in morning or after work. Has never NOT started, but takes an excessively long time once warmed-up. No "Check Engine Light" or DTC's. Was thinking a cam or crank sensor, but temp shouldn't effect those...
Ideas welcomed!
Old 05-05-2015, 09:35 PM
alnvilma's Avatar
This happened on a non Isuzu vehicle of mine. The fuel pump relay was old, weak and would stick when warm. A $5 fix. Can you hear the pump when you turn the key to "on" w/o starting it?
Old 05-06-2015, 08:44 PM
Dr76's Avatar
Just checked "Cold" and could definitely hear the pump. Will check tomorrow after diving when it's HOT. Thanks for the suggestion... will post update soon!
Dr76
03-01-2014 11:16 AM
Campingrich
09-16-2008 05:14 PM
tomb981
01-19-2008 12:39 AM
biglou
01-08-2007 03:40 PM
jscout
02-27-2006 02:02 PM
Quick Reply: Long crank when HOT only
