retreiving check engine light code
Old 08-18-2015, 12:19 PM
gizmo55's Avatar
Default retreiving check engine light code
All I see in the side panel next to clutch pedal are two leads. One has two inlets and the other has only one inlet. Everything I've found online shows a three inlet lead that you use a wire to connect the two outer inlets but my amigo does not have this three hole lead. Does anyone know how to get the cel codes from a 94 amigo?
Thanks
Old 11-22-2015, 05:57 PM
psycho6836's Avatar
ish
IF Help & Suggestion Center
06-13-2013 06:42 AM
sammie white
09-29-2011 10:50 AM
redflash
05-28-2011 01:31 PM
TonyMESC
02-01-2010 05:00 PM
collyswamper
03-22-2008 11:27 AM
Quick Reply: retreiving check engine light code
