retreiving check engine light code
All I see in the side panel next to clutch pedal are two leads. One has two inlets and the other has only one inlet. Everything I've found online shows a three inlet lead that you use a wire to connect the two outer inlets but my amigo does not have this three hole lead. Does anyone know how to get the cel codes from a 94 amigo?
Thanks |
hope this helps..
