Wanted: Light Blue VSV for 2000 TOD Trooper
I have posted a photo at the following address:
http://greenville.craigslist.org/wan/3118469805.html
I'm looking for a Vacuum Switching Valve off a 4-wheel-drive 1998-2002 Trooper or Rodeo (maybe even as far back as 1996). It is part number 8-97101-858-1.
It's located under the car on the front drive axle. It is under an approximately 8" x 6" curved metal shield that has two 14mm bolts.
There are multiple vacuum hoses going to it. It is a light blue connector next to a gray connector - it is hard to miss once you pull off the metal shield.
Please let me know if you have access to this part.
I'm also looking for a radio and cigarette lighter.
Thanks!
John
Thanks!
John
collyswamper
IF Help & Suggestion Center
Mar 22, 2008 11:27 AM
