trooper 4X4 transmission 1986
Old Nov 24, 2005 | 10:15 AM
mrcosmo's Avatar
Can I put a trasnsmission/transfer case from a 1986 trooper II 4x4, 2 door , 2.3 litre 4 cyl gas (manual 5 speed)in a :
1990 trooper 4x4, 4 door, 2.8 litre gas ??? also manual transmission
thanx
mrcosmo
Old Nov 28, 2005 | 12:35 PM
ISUZUGURU's Avatar
Super Moderator
the transfer case is part of the transmission in manuals it doest just simply disconnect.automatics you could.
Old Nov 28, 2005 | 12:51 PM
lowtrooper's Avatar
well, I don't know if you can pop in a 5 speed tranny/transfer case from a 4cyl to a 6cyl engine without using an adapter on the bellhousing. I know that the tranny will have no prob bolting in the chassis because from 86 to 90 the chassis does not change. you also have to check what type of clutch both trannys use. most prob.the 86 tranny uses a cable clutch, and your 90 trooper uses hydraulic clutch.
In my opinion I would use atranny from 89 to 91 troopers with a 2.8 v6engine.
Good luck,
Spartacus
Aug 10, 2011 10:16 AM
tap
Mar 25, 2009 08:51 AM
spearbang
Aug 11, 2008 04:59 PM
DarkSideofWill
I-Mark
Jan 25, 2008 12:56 PM
jiw395
Apr 4, 2006 03:21 PM
