TOD engages at 45-50 mph, check engine light on
Old Oct 31, 2010 | 01:30 PM
pmannlein's Avatar
Default TOD engages at 45-50 mph, check engine light on
I had a complete transmission rebuild, torque converter replaced, transfer case and new pump installed. Bobby's transmission cannot seem to figure out what is casing this and I am looking for some guidance. When I reach 45-50 mph it can see the front (green) TOD lights flash and then I can hear the front wheel drive engage. In addition to this I have noticed the check engine light turn on. the closest Isuzu dealer is a good 4.5 drive to SLC, UT. Does anyone have any advice???
pmannlein
Old Oct 31, 2010 | 08:21 PM
fourwd1's Avatar
Possibly a wiring problem when it was all put back together (broken or smashed wire, missing connector, etc)
Have you checked to see if any CEL error codes have been generated?
tractng
Sep 26, 2010 02:09 PM
14er Man
May 19, 2008 10:56 AM
collyswamper
IF Help & Suggestion Center
Mar 22, 2008 11:27 AM
lashby
Jun 18, 2007 09:09 PM
