Sound in front right hub HELP
Old May 18, 2011 | 08:37 PM
IMYERDAD's Avatar
Default Sound in front right hub HELP
Hello all I just purchased an 87 trooper 2 for 650.00 it runs great 4X4 works.The problem i hve is I get a sound from the right wheel that sounds like a rachet spinning around with a clunk.It does this in 2 wheel drive and only of and on. bearings have been repacked and look good it does have auto hubs.Any suggestion on what the problem is would be a great help. Thans
Old May 29, 2011 | 05:58 PM
redcentinela's Avatar
Check the auto hub assembly. i have the same problem and some folks say the problem dissapear if you replace the auto hubs with manual hubs. I haven't done it because I am not running the trooper.
Old May 31, 2011 | 01:54 PM
IMYERDAD's Avatar
ok got new axel assembley and manual hubs.now another question which is in regards to the motor the trooper originaly had a 2.3 carborated and now has a 2.6 which was fuel injected and now has a 2.3 carb this is the way that i purchased it. There is no computer so what should i do Is there a carb that you would recomend and also if i were to do a motor swap what would be the best i would prefer a disel .Ps cant figure a=out how to start a new post thanks for all your help
Old Jun 1, 2011 | 05:52 PM
Where do you live IMYERDAD? I am asking because diesels for trooper are very difficult to get.
Also, did you mean that you have a 2.6 L engine with a carburator? Just to clarify things.
Old Jun 2, 2011 | 03:18 PM
IMYERDAD's Avatar
it is a 2.6 engine with a carb from a 2.3. I live in idaho i dont know much about troopers . Thanks
Mr. Movida
Sep 20, 2021 12:00 AM
Bart's2001Rodeo
May 7, 2010 03:34 PM
soninlawsrodeo
Nov 16, 2009 11:33 AM
csanche2
Oct 23, 2008 10:03 PM
yorkyc
Jul 2, 2007 05:36 PM
