Rear wheel stud stripped
Old Dec 27, 2008 | 06:07 PM
wclaytor's Avatar
I''ve got a 1995 Trooper with a stripped lug stud on the rear rotor. Is there an easy way (LOL)to pull the rotor off? The only way I see it is to pull the caliper and then break the 4 nuts at the shaft housing.[img]smileys/smiley7.gif[/img] Seems like an awful lot just to pull a rotor... help... please?
Old Dec 27, 2008 | 06:27 PM
JLEMOND's Avatar
Originally Posted by wclaytor
I''''ve got a 1995 Trooper with a stripped lug stud on the rear rotor. Is there an easy way (LOL)to pull the rotor off? The only way I see it is to pull the caliper and then break the 4 nuts at the shaft housing.[img]smileys/smiley7.gif[/img] Seems like an awful lot just to pull a rotor... help... please?
JUST PULL THE CALIPER AND THE CALIPER BRACKET AND THE ROTOR SLIDE RIGHT OFF, OF THE AXLE , JERRY
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Dec 27, 2008 | 07:08 PM
wclaytor's Avatar
The caliper and caliper bracket are off, the rotor is not "sliding right off". I''ll try some gentle persuasion with a rubber mallet tomorrow. But will that get me to the studs? Or are they pressed through the axel hub?
Old Dec 30, 2008 | 09:31 AM
gnr_70's Avatar
Spray WD40 and let it soak for a few minutes....
then gently hammer away.
Old Dec 30, 2008 | 03:10 PM
wclaytor's Avatar
Thanks to all, I got the rotor off with some "persuasion". I did have to take apart most of the parking brake shoe just to get barely enough room to press out/in the stud. What a pain in the [img]smileys/smiley7.gif[/img]... (well you know where), but this forum and some of the links posted made it do-able. Thanks again.
1995 Trooper, 179k and running strong.
Weeze
Oct 17, 2010 09:20 AM
jlslickt78
Aug 31, 2009 08:31 PM
maoder
Nov 9, 2008 10:21 AM
john banks
Oct 27, 2008 08:24 AM
-0000-NH
Oct 2, 2007 06:54 PM
