Rear Suspension Bangs
Old Feb 11, 2007 | 11:52 AM
Breson's Avatar
I have a 99 Trooper. The rear suspension is banging when I pass over even a moderate bump. It is a loud metal to metal thump as the weight of the body is slamming against the frame. I have replaced the springs and shocks but it persists. Any ideas or similar experiences?
Old Feb 11, 2007 | 01:24 PM
chrisl285's Avatar
I have a 99 trooper with the same problem. My first thought was worn out shocks. If anyone has any insight please help!! Edited by: chrisl285
Old Feb 13, 2007 | 07:08 PM
UNCLEMILTI's Avatar
[img]smileys/smiley12.gif[/img]STEP 1; Get out of the car. STEP 2; Look under the back end and see what is clean or shiney from banging into something.
Old Feb 14, 2007 | 10:14 AM
Breson's Avatar
Already did that (first thing actually) it is nothing that I can see, nor the 2 mechanics that looked at it
Old Feb 14, 2007 | 06:49 PM
atfdmike's Avatar
Hi, It could be a worn or missing bushing on the sway bar, or another possibility is a worn or missing bushing on the shock absorber. Sometimes the metal shock bushing gets elongated and allows the shock to strike the bolt on rebound. Sway bar bushing should be tight to bar and bracket...ie: not easily movable. Both take a little investigating, maybe with someone bouncing the car while you observe the suspect area.
Hope this helps
Old Aug 30, 2007 | 11:42 AM
xqzitkid's Avatar
the suspension bump stops could be missing they are tough to see if you don't know where to look if that is it they are a dealer only item. good luck
Old Aug 31, 2007 | 11:28 PM
brotherwulf's Avatar
after market poly bump stops can be bought at any off road shop some times you have to get creative about how you need to get them on
98rodeoS
Feb 28, 2007 06:41 PM
jgabrielson
Feb 6, 2007 09:17 PM
shanks2yu
Aug 5, 2006 10:47 AM
joe larosa
IF Help & Suggestion Center
Aug 4, 2006 10:41 PM
fubar614
Mar 2, 2006 01:14 PM
