Rear Door Rattle
Old Oct 30, 2007 | 11:59 AM
mograham's Avatar
This is probably an easy fix, but I wonder if others out there have experience with rattling in the rear door of their Trooper. I am talking about the rear rear door (with the spare on it). I've driven 4 different troopers over the years (87, 91, 94, 96), and this issue has occurred in the last 2. It pretty much jiggles and rattles whenever you go over even the slightest bump. Why does this occur? Is there an easy fix...known areas that loosen and need to be retightened over time. Not really a big issue, but pretty annoying at times. Any info would be greatly appreciated. Thanks for your help.
Morgan
Old Oct 30, 2007 | 03:16 PM
duckyz's Avatar
Sounds like the spare tire mount is loose. There should be three or four bolts back there you can tighten.
archbid
Jun 24, 2011 05:51 PM
pjl329
Oct 30, 2009 07:35 AM
reybie
Apr 1, 2009 12:38 PM
buickz
Sep 3, 2008 12:16 AM
Vice
Jul 21, 2008 10:34 AM
