Misc fixes on the 93 Trooper 3.1D
1. Brake fluid replaced, brakes feel much better but not 100%
2. Washer fluid neck, pieced together from 1" electrician pipe and clear tubing (OD) from the local hardware store.
Rubbed through and would hold water (serrated piece).
If I remember correctly it was 2x 90deg and the clear tube on the outer part of the electrician pipe -used zip ties to hold it all together. Top part of filler retained. {Couldn't find parts}
Just a visual of the truck I am talking about
3. Rear bumper light array removed and cleaned (stubborn bolts, so I advice caution and lots of spraying down)
4. Vacuum lines replaced.
