Manual x automatic
Old May 17, 2010 | 11:46 AM
issu's Avatar
Default Manual x automatic
hello
I want to know if I can change my automatic transmission and put a manual? what I need? there are new 5 speed for sale? I donīt want sell my car.
thanks
Old May 17, 2010 | 12:10 PM
fourwd1's Avatar
The basics -
You'd need the trans and t-case (I don't think the autos t-case will bolt up to the manual), flywheel, clutch set, clutch master and slave cylinder/lines/hoses/pedal assy. And probably have to do something to make the ECM think the auto is still there, it uses signals from the trans. You may have to do some drive shaft work, I don't know if the lengths are the same or not. And the mounts may be different.
Having a donor vehicle to strip what you need from would be handy.
Gdafpaaa
Jun 22, 2011 03:44 AM
92Trooper
Aug 2, 2008 09:00 AM
gemmett
Oct 20, 2007 11:53 AM
dangingrey
Oct 9, 2007 12:33 PM
sugarbob
IF Help & Suggestion Center
Jan 26, 2006 10:49 AM
