keep blowing fuse for inside dash lights
Old Oct 9, 2008 | 09:44 PM
isuz's Avatar
my isuzu trooper keeps blowing fuses for the interior dash lights and the tail lights can anyone tell me why?
Old Apr 18, 2018 | 04:41 AM
Sarahp91's Avatar
I have the same problem... any advice
Old May 19, 2018 | 12:24 PM
98trooperoffroad's Avatar
I have a 98 trooper mine did this to when I got it found out the radio was wired wrong and the plate light had an LED causing a short
Old Sep 2, 2018 | 08:56 PM
jbmotorwerks20's Avatar
Thumbs up
Fuses will only blow because of either an overload, or a short to ground (hot wire grounding out). Check all of your interior lights starting with the easiest to get to and work your way around the circuit, you'll find the problem. You may also have installed something that's drawing more amperage than the circuit was intended, so check anything you may have installed aftermarket. Another method would be to disconnect things until the fuse stops blowing, then you'll know exactly where the problem should be. What ever you do DON'T JUST INSTALL A HIGHER RATED FUSE, that will eventually cause more damage than already exists.
Old Oct 31, 2018 | 06:54 PM
Big Greek's Avatar
LED light in rear license tag will blow the taillight fuse in engine compartment...15A, easy to replace...do not use the LED
Old Mar 4, 2020 | 09:12 PM
Werdnagol's Avatar
Hi Isuz
Did you find the cause of your electrical problem on your ISUZU?
Old Mar 4, 2020 | 09:14 PM
Werdnagol's Avatar
Hi Isuz
Did you find the cause to your electrical problem on your Isuzu?
Old Mar 4, 2020 | 09:15 PM
  #8
Werdnagol's Avatar
Hi Isuz
Old Jan 4, 2021 | 11:40 AM
  #9
Susan Cyr's Avatar
Originally Posted by Werdnagol
Hi Isuz
Brake lights and dash lights not working on a 1998 trooper
Airis Airis
Apr 16, 2019 03:25 PM
roamer
Jan 29, 2016 07:23 PM
Trooperguy
Aug 28, 2007 07:35 AM
driver
Sep 16, 2006 10:39 PM
trooper
Jan 26, 2006 10:55 AM
