Heater Duct Blend Door
Old Feb 9, 2019 | 05:10 PM
BWolfeTrooper's Avatar
Default Heater Duct Blend Door
2001 Isuzu Trooper:
Intermittently the ducts will not blow any air at all when it gets really cold outside upon start up. The fan is working it's just not pushing air through the vents in any mode, so apparently the mode door is not opening inside the heater box. I put a box heater on the floor board and everything works fine after it heats up the components. When it doesn't work there is free flow movement from the fan box through the a/c condenser and then it is restricted somewhere in the heater box.
skorch1ss
Aug 11, 2012 02:30 PM
millhouse76
Jan 20, 2011 10:36 AM
auswalk
Jun 1, 2009 01:43 AM
angelorumart
Nov 2, 2007 11:51 AM
knuckles
Jun 6, 2006 01:28 AM
