HE 98 3.5 V6 trooper
Old Dec 1, 2007 | 10:30 PM
seantg's Avatar
plugs 1,3,5 foul and the fuel economy is terrible
the check engine light is on
i get a code P0300 multiple random misfire
the car seems to run fine
when i clean the plugs and its cold
for about 20 min
then it stumbles on acceleration
i have swapped the injectors , coils ,removed the cats,& mufflers
swapped plugs on the 02 sensors
soaked intake with carb cleaner
im thinking fuel pressure regulator , or bad timing on camshaft passenger side i think it may be off a few teeth
but it runs fine when its cold .....
the engine is smooth at idle .....
its when u drive it thats its a problem .....
i dont know what else to do
taking off the timing cover is a last resort thanks .:Sean:.
Old Dec 2, 2007 | 10:59 AM
badloser's Avatar
It might be the ECU . The ecu has Injector driver that might me misdelivering fuel.. just a thought
Old Dec 2, 2007 | 12:14 PM
seantg's Avatar
but is is possible for only one side of the engine ?
i will look into this i have some pics of the plugs
they r from left to right 1,3,5 &amp; 2,4,6,
http://www.auctiva.com/hostedimages/...aspx?gid=63260 8&amp;image=88389090&amp;images=88389090&amp;forma ts=0&amp;f ormat=0&amp;lgdin=1
http://www.auctiva.com/hostedimages/showimage.aspx?gid=63260 8&amp;image=88389116&amp;images=88389116&amp;forma ts=0&amp;f ormat=0&amp;lgdin=1
http://www.auctiva.com/hostedimages/showimage.aspx?gid=63260 8&amp;image=88389124&amp;images=88389124&amp;forma ts=0&amp;f ormat=0&amp;lgdin=1
http://www.auctiva.com/hostedimages/showimage.aspx?gid=63260 8&amp;image=88389168&amp;images=88389168&amp;forma ts=0&amp;f ormat=0&amp;lgdin=1
http://www.auctiva.com/hostedimages/...aspx?gid=63260 8&amp;image=88389239&amp;images=88389239&amp;forma ts=0&amp;f ormat=0&amp;lgdin=1
http://www.auctiva.com/hostedimages/showimage.aspx?gid=63260 8&amp;image=88389256&amp;images=88389256&amp;forma ts=0&amp;f ormat=0&amp;lgdin=1
</span>< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Edited by: seantg
Old Dec 2, 2007 | 12:20 PM
badloser's Avatar
are you running stock plugs? Try gaping them just a little less to see if they burn all the fuel off then.
Old Dec 2, 2007 | 07:13 PM
seantg's Avatar
when i got it it had regular NGK plugs
then as part of the trouble shooting process
i put in the NGK platinum plugs u see in the pictures
so what i will do is make the gap a little smaller on the 3 im having the
problems with
im going to do that right now !!!
thanks for the suggestion .:Sean:.
< ="text/">
Edited by: seantg
Old Dec 3, 2007 | 05:54 PM
badloser's Avatar
yes I hope it helps I had a similar problem with a Evo 8 that I had and I ended up gapping the plugs at at .240 to make it run right
whitetrooper
Apr 21, 2021 02:10 PM
89Trooper
Jun 15, 2006 03:54 PM
