first isuzu bucking when in gear....
Old Aug 19, 2011 | 07:23 PM
fairlane11's Avatar
Default first isuzu bucking when in gear....
Hello, This is my first Isuzu. It is a 1993 Trooper LS, 4X4, automatic. 232,000 miles. It idles fine and revs fine. However when in gear it has a bad miss or seems to be missing, when on the gas it is very rough and takes forever to gain speed. It seems to be backfiring ( popping in the exhaust). The previous owner gave up on it after investing lots of money. It has new coil packs plugs and wires, I can see those and I pulled 2 plugs 1 from each side and they are gaped at .040. He says it has a new fuel pump,fuel lines,filter. The truck was on empty when I bought it about 3 hrs ago. I put 20 bucks in it so I know the gas is good. He also had the timing belt replaced,it looks new because the top cover is missing. I'm thinking it's a timing issue, but not sure.Any ideas would be helpful. Thanks.
Old Aug 20, 2011 | 05:52 AM
Lunchbox21984's Avatar
thats what i would do, get the timing set and see if that works. sounds like it might be off a tooth or two. get it set and report back.
Old Sep 2, 2011 | 08:48 PM
fairlane11's Avatar
ok, I found my troubles. I had a friend of a friend check the timing and it was correct. So long story short I pulled all the plugs and found 4 of the 6 were bad. My luck the first 2 i pulled were the good one's. I started from scratch and found 1 bad coil pack and found 2 injectors not firing. I pulled the intake and cleaned the injectors and I am happy to say it runs like a brand new truck.
DriftingSon
Apr 25, 2020 11:50 PM
jbrandall89
Oct 13, 2012 11:36 AM
toastzodiac
Feb 14, 2010 10:44 AM
ckctroop
Feb 7, 2009 12:08 PM
icesphere18
Mar 3, 2006 08:56 PM
