Cranks but won't start.
Old May 20, 2011 | 09:58 PM
drdavid13's Avatar
Default Cranks but won't start.
I have a 1998 Trooper 3.5, did not have many problems with it. I change the starter two years ago, no problem with that. A week ago I started the trooper and let it heat up, then I drove for a mile, and all of a sudden. it turn off while driving. Like there were no gas, I check the fuel pump and its good. change the filter, have good gas presurre, spark at the plugs, current at the crank angle sensor, current on the injectors, still won't crank. change the fuel pump relay just in case, change the ecm relay, still nothing.
I don't know if anybody had this problem, what should I check next? I am all ears, thanks.
Old Oct 25, 2011 | 11:09 PM
haroldjr's Avatar
i wish i knew im having same problem. going nuts
mrjpnagy
Dec 14, 2012 07:59 AM
drdavid13
May 20, 2011 09:48 PM
JASPER081377
Mar 2, 2009 01:03 PM
wrw1
Mar 7, 2008 10:58 PM
