Cranks but won't start.
Old May 20, 2011 | 09:48 PM
drdavid13's Avatar
Default Cranks but won't start.
I have a 1998 Trooper 3.5, did not have many problems with it. I change the starter two years ago, no problem with that. I started the trooper and let it heat up, then I drove for a mile, and all of a sudden it turn off while driving. Like here were no gas, I check my feul pump and its good. change the filter, have good gas presurre, spark at the plugs, current at the crank angle sensor, current on the injectors, still won't crank. change the feul pump relay just in case, change the ecm relay, still nothing.
I don't know if anybody had that problem, what should I check next? I am all ears, thanks.
mrjpnagy
Dec 14, 2012 07:59 AM
drdavid13
Oct 25, 2011 11:09 PM
JASPER081377
Mar 2, 2009 01:03 PM
wrw1
Mar 7, 2008 10:58 PM
