Clutch not engaging HEEELP!
Old Jul 28, 2011 | 06:44 PM
Murdermobile's Avatar
Default Clutch not engaging HEEELP!
Ok so i replaced the Clutch, the Flywheel, The master Cylinder, The Slave cylinder. And ive been bleeding it for the last 6 hours. And the clutch will still not engage. What am i doing wrong? Please HEEEEELP!
Old Jul 30, 2011 | 07:14 PM
Lunchbox21984's Avatar
did you change out the throw out bearing as well??? and did you make sure the fork was working correctly before you put everything back together?? and are you sure its not on a Clutch Cable? if its Hydraulic, then make sure you got all the air out of the line, by bleeding the system.
Old Aug 13, 2011 | 09:35 PM
Its a hydraulic system, I had it changed by a backyard mechanic. now im having to go behind him and re-do everything he did to make sure. thanks for the advice.
Old Aug 13, 2011 | 10:01 PM
yea, but if its a hydraulic system and it has air in the lines, then you need to bleed the system and get the air out. As for the Throw out bearing, it sits in the pressure plate. good luck.
Old Aug 14, 2011 | 04:53 PM
bill-costa rica's Avatar
sounds like you have a throw out bearing hanging up or in backwards. the hydraulics dis-engage the clutch. maybe the clutch plate is in backwards? or with luck the adjustment on the linkage is out of whack.
bill-cr
Old Aug 14, 2011 | 06:07 PM
bill-cr
The linkage could be out of adjustment, thanks Bill, i forgot about that. I got a Cable adjusted clutch on my 84 4speed man. and i haven't even had to adjust it yet. good point out there bro.
Old Aug 25, 2011 | 07:07 PM
Linkage adjustment? this is the first ive heard about any of these things. needless to say im a novice when it comes to trannys. is there any resource online that i can find specific instructions on how to do this?
Old Aug 26, 2011 | 12:49 PM
  #8
your adjustment will be down at the slave cylinder. the rod that goes to the throw out bearings arm that sticks out of the bell housing.
when pushing down on the clutch pedal you should have 2 or 3 inches of travel before you get any resistance. if you have no free travel that would be your problem.
there are a few utube videos on how to adjust a hydraulic clutch.
bill-cr
Old Aug 29, 2011 | 07:55 AM
  #9
troopergeek's Avatar
when replacing these components you shouldn't need to adjust anything unless the adjustment was changed during the repair. is the throw out bearing fork not engaged on the pivot ball?
Old Sep 13, 2011 | 10:22 PM
  #10
Just got a new clutch from clutch specialists, (third one) now i have it all put back together and it has no air in the lines (or so it seems) and my slave cylinder is not moving..... im about another 25 dollar part from setting this thing on fire......
