burning lots of oil
Old Nov 30, 2009 | 08:50 PM
tom clark's Avatar
Default burning lots of oil
i bought my wife a 99 isuzu trooper and i ran into a bit of a problem, in 1,000 miles if all or most on the highway it will burn about 2 qts of oil. i know there aren't any leaks because i put it on the lift at work and i looked around, it was clean. has anyone experienced this before? where should i start?
thanks,
tom clark
Old Dec 23, 2009 | 02:50 PM
poooland's Avatar
im in the same boat. replaced all leaking gaskets. and not a leak on the vehichle. still burns about a quart every two weeks? Everything I have read seems to agree.
Old Dec 25, 2009 | 01:57 PM
oefvetisuzutrooperlover's Avatar
Exclamation type of oil
what type of oil are you using? maybe switch to a thicker oil i.e. 10w30 oil . also try some lucas oil stabilizer
Old Dec 26, 2009 | 09:54 PM
tom clark's Avatar
i'm using conventional 5w30 but am going to switch to 10w30 and have heard of people switching to 15w40 but i am not quite sold on using that heavy of an oil. i am also going to try pulling the spark plugs and putting some top engine cleaner in each cylinder and letting it set over night, i've been told about a common problem with the 3.5 where the ring will build up carbon and allow heavy oil consumption, the top engine cleaner should clean out a lot of the carbon if that is the problem.
Old Dec 27, 2009 | 09:01 AM
keep us posted. as stated bfore, if i tow something uphill of for extended distances, i tend to lose oil. other than that, my oil usage is normal.
Old Dec 28, 2009 | 09:16 AM
chumpep09's Avatar
as stated in title i have a 2tc in my silly car at the moment and it burns abit of oil i know it isnt leaking any where and it isnt the rings because it still has compression what else could it be??
Old Dec 31, 2009 | 05:05 PM
Kevin R's Avatar
Default Problem iwth all 98-02
There is nothing you can do to stop this it is a problem with 1998-early 02.It is due to inadequate drain-back holes in the oil control rings.If you look on the internet you will find everyone that has a trooper in these years all have this problem.In late 2002 they did fix the problem but by then it was to late and they stopped making the trooper.There are acouple of things that will help.One is taking off the EGR valve and cleaning it and making sure the PVC valve is good and clean.
Old Jan 1, 2010 | 01:25 PM
  #8
reson2's Avatar
We used to have a lot of oil burning issues with the dealers that used Quacker state and Penzoil, the oil is good, it lubricates great, but on some engines it cokes in the rings, sticks them right up, and plugs the breathers - once they get resricted they start to syphon the oil right into the intake. The only product I ever had success with was one made by AC/Delco called X-66, (I think the X-88 is a penetrant, I mix them up) you can get it in arosol cans, it is now advertised as a throttle body cleaner, it used to be used to dissolve carbon on piston tops in Cadillacs and the AMC 258 six, they would rattle like they were ready to blow, warm it up pour this in and kill the engine with the last bit, let it set overnight and in the morning fire it up, large cloud of the worst smelling smoke - and the noise would be gone! It also cleans valves nicely, in used engines that have sat for a time, time and a half, the carbon grows and keeps the valves open, this stuff really helps! It may just open up the oil return holes and free stuck rings for you too! ;-)
Old Jan 1, 2010 | 04:43 PM
  #9
wheily's Avatar
seafoam worked on mine went back to a quart every 3 mounths
dukefan52
Nov 24, 2008 11:09 PM
keithcharrison
Oct 31, 2008 07:44 AM
Gizmo42
Mar 1, 2008 07:31 PM
IsuzuKid
Oct 2, 2007 10:58 PM
PIGS
Jun 8, 2006 12:38 PM
