ANOTHER TOD question
Old Mar 10, 2009 | 04:59 PM
trooperdrury's Avatar
Default ANOTHER TOD question
Hey i just discovered this site, and have been researching the TOD issues here. I have a 2002 Trooper with TOD. the two rear tire lights (on the tod indicator) flash all the time now, once and awhile the red check will come on and flash too! HOWEVER all systems work fine. The 4WD low works no problem, and then when i push the 4WD auto button, it engages. when i shut it off the two wheel system is back on. I tested this on a STEEP hill with a dirt road, in 2wd, it spun the rear tires all the way up the hill, with the 4wd auto button pushed, not one slip! So is this the sensor on the transfer case everyone eludes to that is causing this gauge to flash when in 2wd? Any help or clarification is VERY welcome!
thanks
Old Mar 18, 2009 | 02:49 AM
bigman5956's Avatar
sorry my 95 trooper doesnt have the fancy gadgets but my guess is that it could be the sensors or something if you say its works solid
dane
Jul 29, 2007 02:56 AM
crashjt
Jun 18, 2007 09:02 PM
irupp33
Sep 25, 2006 09:47 PM
15uzu
Aug 16, 2006 06:54 AM
