AM/FM Cassette Radio (stock) Quit Working - 1998 Trooper
Old Nov 14, 2009 | 01:19 PM
yukonjoe's Avatar
Default AM/FM Cassette Radio (stock) Quit Working - 1998 Trooper
Any ideas as to why my factory installed, stock AM/FM cassette radio may have quit working? Scenario: Radio playing fine; tried to change channels and heard beeping like I was setting presets (I wasn't); None of the buttons with presets would work to change station; radio would NOT power off; turned ignition off and on and no change; same as described above. Pulled 20 amp fuse for radio; turned ignition to Accessory and no power to radio at all; replaced the 20 amp with original fuse and tried again - no power to radio. Bought new 20 amp and 10 amp fuse (there are two fuses that relate to audio); tried new fuses to no avail - no power whatsoever to radio.
All other accessories and electrical seem to be working properly - including power mirrors that are powered off of the same 10 amp fuse that powers radio (Acc).
Currently I have new fuses in the 10 and 20 amp audio slots.
Any thoughts or ideas from fellow forum members welcome and appreciated.
Old Nov 14, 2009 | 06:41 PM
wheily's Avatar
i wonder if there is some kind of reset on the radio it self . my 88 had a fused wire be hind the passinger headlight that ran the radio hopfully they changed that desighn id pull the radio out and see if ther is power going to the radio it may have just died
Old Nov 21, 2009 | 03:48 AM
mdkdragon's Avatar
could not have said it better my self
moparman64
Dec 29, 2018 02:32 PM
Quezz5
Mar 26, 2013 11:41 AM
troutslayer
Feb 4, 2011 02:55 PM
ecm garrett
Jun 8, 2007 02:18 PM
zbudah
Jan 7, 2006 11:24 PM
