96 3.2 sohc engine ticking
Old Apr 27, 2008 | 09:25 AM
shawnferg23's Avatar
my 96 trooper has had a ticking in the motor since i bought it. i hear from others its pretty common. infact i had an isuzu p/u that did the same but i couldnt figure out what made that noise. oil pump? lifters? baffled man baffled
_uacct = "UA-939292-44";
Old May 30, 2008 | 12:33 AM
brndncuz's Avatar
I HAVE SAME EXACT PROBLEM, ANY HELP?? SHAWFERG DID YOU EVER COME UP WITH SOLUTION? IM BRAND NEW HERE AND LOOKING FOR ANSWERS, IM FAR FROM HOME, IM MILITARY SO I CANT TAKE VEHICLE HOME TO TRUSTED MECH'S, HELP IF POSSIBLE
Old May 30, 2008 | 08:48 PM
actually i still have the same problembut the truck is still running strong with the acception of bad gas mileage. i still havent found a solution but i think ill just save up for a used motor and drive the other one into the ground. i think that the problem is in the upper motor like in the valve train because its a fast tick that speeds up as the rpm's increase. by the way im military too. where are you stationed?
Old May 30, 2008 | 09:34 PM
MASTERTECH's Avatar
all of the old sohc have a lifter tick you can make the noise go away by only sure fix thing or try a temp fix. 1st you can replace the rocker arms and shafts but this is very costly. the other is to use 0w-30 mobile one, oil after you change it run the engine at 2000 rpm's for 30 minutes. if the noise goes away your ok then go back to your old oil next time. but I found this only helps for a short while, the next thing you can try is 15w-40 rotella oil for diesels, it will clean up the inside of your engine. Where are you located at I might know a Isuzu Tech in your area that you can use and trust
Old Jun 4, 2008 | 08:17 PM
crystaladam08's Avatar
Ticking in these motors is extremely common. Go onto the Rodeo board and you will probably find a 1000 posts on it. I have seen these motors last an incredibly long time while ticking.
Old Jun 4, 2008 | 11:07 PM
i tried using rotella 15w40 and it helped quiet the ticking for the first couple days but with some hard miles it came right back. the problem with the ticking doesnt bother me but trying to sell it with a ticking noise does because noone will buy it with that noise. ill just do a head job and be done with it
Old Nov 2, 2008 | 05:02 PM
good.solutions's Avatar
I had heard/read that this was common and mostly ignored it. Despite all scheduled maint./oil changes, etc. since new, my 96 3.2SOHC ran to 149,543 when it sucked spark plug seat and plug down into Cylinder 6. Imagine the damage! Block is unsalvageable. Be careful.
vamootsman
Sep 9, 2007 03:43 AM
vamootsman
Dec 20, 2006 12:40 AM
danricker
Apr 1, 2006 01:11 PM
dabeef7
Mar 4, 2006 05:11 PM
gforce
Mar 3, 2006 07:43 PM
