95 Trooper DOHC 4wd no power to ac/heater
Old Aug 15, 2012 | 01:57 PM
beachfairymd's Avatar
Default 95 Trooper DOHC 4wd no power to ac/heater
Heres the issue: radiator fan shroud came loose and got stuck in the belts apparently causing this issue because there is now no power to the ac/heater controls/ the compressor or blower does not operate. I checked the fuses i can see....is it a relay? I am thinking/hoping someone here might have knowledge of if something tripped or what? I know there are some relays for this system, do they reset or you have to test and replace them?
i should mention that the battery light on the dash is on but the alternator gauge appears normal so i think that is telling me...that i have a power related issue...which i know...just dont know how to remedy it.
beachfairymd
Aug 14, 2012 03:01 PM
sheltonjason
May 10, 2012 07:13 AM
jamracer21
Mar 19, 2010 03:28 PM
goingcrazy
Dec 19, 2008 11:21 AM
big bear
Sep 7, 2007 06:33 PM
