94 trooper spark problem!!!!1
Old Mar 24, 2007 | 09:14 PM
joshuataulbee05's Avatar
just replaced Ignition control module (2x), crank position sensor,
still no spark @ coils. cant figure it out, its driving me crazy!!!!
please help!!!
Old Mar 26, 2007 | 03:08 PM
atfdmike's Avatar
OK, need a little more info to try to help. May or may not make a difference, but which engine, DOHC or SOHC? Why did you start replacing parts.......did it quit, lose power, ??? Why did you do to determine the parts you replaced needed replacing? Maybe then more of us can help. Other possible areas are the ignition switch, ecm or wiring harness, so before you start swapping parts, try to diagnose what is not working along with what is. Hope this helps you get started.Edited by: atfdmike
cloudconnected85
Apr 4, 2012 09:26 PM
surpera1
May 11, 2009 02:08 PM
rromo
May 30, 2008 09:44 PM
SamG
Jan 8, 2008 02:03 PM
maddad
Jul 3, 2007 01:22 PM
