92 Isuzu Trooper Axles
the stock Troopers only had an Isuzu LSD (limited slip dif) in the rear, so I doubt that you have one in the front unless someone installed it. If you have a locker in front, they are great off road but on surfaces with traction they tend to only want to go straight so are tricky to drive when you need to turn.
Hope this helps
