90 Trooper 4cyl fuel problems
Within the last 50 mi:
Running ruff - Replaced plugs, wires, cap & rotor.
Runs fine.
Wouldn't start - No fuel, replaced fuel pump. Runs fine.
Wouldn't start - Replaced burnt wire/connector from
fuel pump relay at fusebox. Runs fine.
Burst fuel line - Replaced flexible hose. Runs fine.
Running ruff, stumble home to find fuel purging from the evaporation cannister?? Fuel tank is highly pressurized. No Check Engine light. What's Happening??
Runs fine.
First time I dropped the tank and replaced my fuel pump....I struggled to get it primed and running for a week. Turned out to be a clogged fuel filter. Forgot to replace that inexpensive in-line component.
