88 trooper problem
Old Jan 30, 2010 | 10:44 AM
flamefighter2's Avatar
Default 88 trooper problem
i have an 88 trooper. it wont run. i have tested spark, compression, and fuel and all are great. the only thing i can think of is the injectors are not spraying at the right time. does anyone know what tells the injectors when to spray? thanks so much
nick
Old Jan 30, 2010 | 02:26 PM
Tater1945's Avatar
Default won't run
It can depend on what engine you have. If you've got the 4cyl, I'm pretty sure the engine is not fuel injected, although I might be wrong. I had an 87 at one time and it did not have a TBI.
If it is, there's an ECM that would tell the injectors what to do. Getting any codes of of that might help you figure out what's happening
If it isn't, then I'd start looking for big vacuum leaks, timing property set, etc.
Old Jan 30, 2010 | 04:01 PM
Default tater
thanks for the info. it is fuel injected. it is not throwing any codes. it runs great if is stuff a gas rag in the intake. i have no clue.
joshuataulbee05
Mar 26, 2007 03:08 PM
89Trooper
Mar 24, 2007 04:23 PM
lashby
Sep 22, 2006 11:00 AM
joentraci
May 9, 2006 10:51 PM
kiteskier
IF Help & Suggestion Center
5
Nov 29, 2005 08:49 PM
