85 Trooper - no power under load
Old Dec 1, 2008 | 05:57 PM
miketreid's Avatar
I have just purchased a 1985 Trooper and am having a problem getting power under load.
I have rebuilt the carb (use not to run at all), changed the plugs, wires, cap, rotor, oil, filter. Set the timming @ 6 deg.
I have messed with the timming some but it is not helping. I have drained the tank and put in new gas also.
It runs great when sitting still.
When you take off, it kind of sputters. And when you get into it it does not want to go it hesitates and jerks some,
Any help would be great.
Thanks in advance.
Old Dec 2, 2008 | 04:02 AM
ARMYTROOPER's Avatar
I have a 94 trooper and had something like that too. I found that the timming belt was off by just one tooth and that the cat was cloged. After fixing both I have more than enough power and no more sputters. Good luck.
mtanaka
Jul 6, 2010 02:58 AM
jstar41
Nov 19, 2008 04:00 PM
dogma2oo3
May 30, 2008 12:46 PM
kerry howard
Mar 9, 2008 02:37 PM
isuzu_racer
I-Mark
Aug 26, 2006 08:06 PM
