1999 trooper gas leak
Old Nov 5, 2010 | 11:21 AM
ksweetman285's Avatar
Default 1999 trooper gas leak
i was wondering if any one has had this proublem, i have a gas leak on the front end i think its the main line must be return bc it runs fine and its leaking pretty bad , my question is how do you change the lines they are hard to get to i cant even touch them bc the exaust is in the way , or if anyone has had this done in the shop how much did it cost thanks
Old Nov 5, 2010 | 11:23 AM
forgot to add its the two rubber lines that go to fuel rail to the steel pipe between two front tires thanks
Danus
Oct 11, 2012 04:01 PM
Chris in Idaho
May 23, 2011 06:11 PM
TexTrooper
Private 'Wanted' Classifieds
Jan 27, 2009 03:10 PM
jeffg
Feb 1, 2008 12:08 PM
MS39047
May 11, 2007 01:05 PM
