1994 Trooper Door Speaker Wiring
Old Dec 28, 2010 | 05:15 PM
auhsojrm's Avatar
Default 1994 Trooper Door Speaker Wiring
Hello everyone,
My girlfriend just got a used 1994 trooper and I wanted to help her replace the stock radio and speakers but I am having difficulties. Here are a few concerns...
When looking at the old wiring harness for the radio, I understand what all the color coding is... right front, left front, etc... but when I took out the speakers in the doors, there is "2-way Co-axial" wiring inside the doors. Meaning that the main left and right speaker wires are getting split somewhere along the line to power a separate tweeter and woofer set-up(2-pairs of + and -). Is there an amp or cross-over somewhere in the dash that's easy to access?
Because I was unsure, I decided to rewire the doors for my new speakers without using the existing wires. The big problem I am facing now is...how in the world do I get the wires through the doors and into the chasis of the car or vice-versa!? the hole where the wires should come through is covered by a huge assembly of separate wire harnesses and some sort of circuit board or junction box for these hundreds of wires(this is the right door, btw), and I cannot get anything thru. Do I need to remove all this to feed the speaker wires? And will this be the same on the left side as well?
We live in costa rica and I can't afford to mess anything up...parts are soo expensive here.
Thanks,
Josh
engineeringpunk
Apr 5, 2012 04:46 PM
dan5505
Jun 7, 2008 02:12 PM
Jeff
Jul 4, 2007 09:24 PM
ecm garrett
Private 'Wanted' Classifieds
Jun 8, 2007 02:24 PM
passport105
Nov 15, 2006 04:25 PM
