1988 2.6L Idleing Problems
Old Apr 1, 2009 | 11:29 PM
wondergeek's Avatar
Unhappy 1988 2.6L Idleing Problems
Hey, I have an 1988 with a 2.6 and it will not idle when it gets warm. Once it gets warmed up, then the engine revs and then goes to idle, and so on and so on, until I either speed up, or shut it off. What could be the problem/s?
Old Apr 2, 2009 | 07:46 AM
trooper95's Avatar
water????try putting more water / coolent. check your plugs and wires
Old Apr 2, 2009 | 07:55 PM
Moutain_Ox's Avatar
you need to clean your icv. or get a new one. they get gunked up overtime an sart to mess up. thus the idle cycling when warm.
quick note; before you do replace or clean it. take a moment to check your vac lines. could be a small intake leak causing that as well .but if your vac lines are good you know what to get after.
Old Apr 3, 2009 | 07:01 PM
Merc40's Avatar
excuse the newbie in me....what is an ICV?
Old Apr 3, 2009 | 09:14 PM
wondergeek's Avatar
I found out what an ICV is; the Idle Control Valve. However, where is that particular item on the engine?
Old Apr 4, 2009 | 08:57 AM
Merc40's Avatar
Thanks
Old Apr 4, 2009 | 06:23 PM
Moutain_Ox's Avatar
look it up on a auto parts web site i.e autozone. the icv is located on the intake manifold. get a pic of waht it looks like an i am sure you can find it pretty quick
Old Apr 5, 2009 | 02:34 PM
  #8
wondergeek's Avatar
Default Thanks
Thank you Merc40.
Old Apr 25, 2009 | 12:02 PM
  #9
Merc40's Avatar
Did you get it fixed?
Old Apr 26, 2009 | 03:23 AM
  #10
wondergeek's Avatar
Default Not Yet, Rebuilding the Engine
No. I haven't fixed it yet. I am planning on getting that during my engine rebuild.
