turning off the horn
Its the same procedure for turning it on or off. If its already on, doing the procedure should turn it off. Sometimes it takes a few tries to get it. I've done it a couple times on mine, took several tries.
OK i tried 10 times nothing happens!! am i supposed to get a
response from the door lock or what? I am locking the door 3 times shut
it twice lock 3 more times then shut and open the door again. What am i
missing?
missing?
Sounds like you are doing it right as long as you are doing the lock/unlock within 10 seconds and the close/open as fast as you can.
I just did it on mine. Half the time it worked. When it works the door will lock then unlock once. The manual says if it fails it should lock/unlock 3 times but when it failed on mine it did nothing.
Start with the door unlocked and closed for a minute or so, then open it and do the procedure. I know it works on mine atleast [img]smileys/smiley8.gif[/img]
Are you guys talking about being able to turn the horn off when you lock/unlock the doors with the keyless entry? I kinda find the horn on this thing to be somewhat annoying, so if you can make it stop beeping when you lock/unlock the door I wanna do it.
If i'm right, could you lay the steps out for me. If I'm not right, well then ignore my stupidity. [img]smileys/smiley4.gif[/img]
Yep thats what we are talking about.
1. Drivers door open.
2. Insert the key into the driver's door key cylinder, and turn to lock and unlock 3 times (lock -> unlock -> lock -> unlock -> lock -> unlock) within 10 seconds.
3. Close and Open the door 2 times (close -> open -> close -> open) within a 10 second period.
4. Turn the key to lock and unlock 3 times (lock -> unlock -> lock -> unlock -> lock -> unlock) within 10 seconds again.
5. Close and Open the door.
Response of door lock motor (Lock, Unlock once if successful. Lock, Unlock 3 times if fail).
I have mine on but I replaced the horn with an 'american' style horn so it doesnt sound so goofy.
Edited by: Gizmo42
