transmission check/fill plug
Old Mar 31, 2012 | 08:52 PM
elsleepster's Avatar
Question transmission check/fill plug
I was checking my fluids on the differential, transfer case and transmission. I have a 98 Rodeo with a automatic transmission with no dip stick and had a hard time finding the filler check plug. I stumbled across a diagram showing the check/filler plug about 6 inches from the drain plug.
transmission check/fill plug-91097106.gif
I talked with a mechanic today and the filler check plug is the higher of the two on the pan. Said it needs to be running in neutral on a flat surface.
Never knew how convenient having a dip stick was til now!
tonytwotime
Jul 8, 2013 04:34 PM
bali kute
Jun 28, 2011 02:41 AM
aznxstazy
Feb 6, 2010 12:51 PM
pankary
Mar 11, 2008 08:59 AM
pedro62
Jan 31, 2008 06:21 PM
