Trans Pan bolt Torque Spec???
I am getting ready to change my ATF and Filter. Does anyone know what the torque specs are for the filter and for the pan bolts. I assume the front pan has the same specs as the larger pan with the drain and fill bolts in it. I appreciate any help. This is a 4l30e, 2000 Honda Passport which is nothing but a Isuzu Rodeo with Honda badging. I am leaking ATF but it doesn't seem to be coming from the accumulator, but I ordered a new one anyway as well as changing ATF pan gaskets.
Thanks for the help.
