Fill ATF in Park or Neutral
Old 01-30-2008, 05:26 PM
pedro62's Avatar
I serviced the 2000 Rodeo ATF in Park but I think I have also read a post or two that says neutral. The Chilton Manual says Park.
I would be interested in the forum techs opinions & the reason(s) for it if you are willing to reply.
Also, does anyone know if the fluid has to be drained to change the accumulator piston cover?
TIA,
Pete
Old 01-31-2008, 06:21 PM
I think the cover can be changed without draining, but I'm not positive. I've never done one. I dont even have an automatic. As far as I know checking the level should be done in neutral. I've also heard to manually shift through all the gears, then put in neutral to check. If nobody can give you a difinitive answer on the cover on here sign up on planetisuzoo.com and ask there. I know there are alot of ppl there that have changed the cover.
elsleepster
03-31-2012 08:52 PM
bali kute
06-28-2011 02:41 AM
Smittysmymechanic
05-19-2011 04:00 PM
pankary
03-11-2008 08:59 AM
dsenatore
01-03-2008 09:51 AM
Quick Reply: Fill ATF in Park or Neutral
