leaking coolent -- 95 v6
i have a 95 3.2L v6 rodeo with 145k miles. I was about to park and my car made a funny noise when i had the clutch in. I parked, got out and noticed it was leaking something. I was in a hurry and couldn't investigate so i just left it parked. A day later i looked at it again and noticed it was antifreeze, however my reserve seems fuller than it was and there is a piece of tubing that ends near the reserve that doesn't seem to be connected to anything (i am not sure if this is the overflow tube). it is still leaking slowly even though it hasn't been driven. I can't tell where it is leaking from, but it is gathering on the edge/seam of the oil pan. Just wondering what might be leaking, what i can do, or if i should take it in to a mechanic. thanks
</>I had/have the same problem with my rodeo. It was leaking but yet the reserve tank was full. Well, my problem is that it is leaking from the water pump. You might want to look at the pump and see if this is the problem. Mine started off as a slow little drops and then now it is a trickle</>
_uacct = "UA-939292-44";
</>Edited by: 95.5 rodeo6
