Tire & Wheels for 96 Rodeo 4-Dr. LS
Old Mar 1, 2008 | 11:01 PM
Mike124's Avatar
What size backspacing do i need to fit 30x9.5-15 w/ 15x8 rims on my rodeo. I'd stick with what i have but rusty steel rims and highway tires that spin in mud an let me powerslide (drift) around corners easier then i like them to, not that a problem, fun until hit snow bank or curb.
Thanks for any help,
Mike
< src="http://www.google-analytics.com/urchin.js" ="text/">< ="text/">_uacct = "UA-939292-44";
< ="text/">
Edited by: Mike124
Old Mar 1, 2008 | 11:36 PM
30x9.50 should work with any rim backspacing on a gen 1.5 rodeo with no problem. They have larger wheel opening then the 2nd gen I have.
I'm not sure what the back spacing is on his wheels (they are 16x8 MB Blitz) but Ramblin Fever has 265/75-16 (same as 32") on his '97 and had no rubbing issues even before his 2" lift..
Edited by: Gizmo42
Old Mar 2, 2008 | 04:32 AM
Mike124's Avatar
Dumb question, what the factory backspacing .
Thank You,
Mike
Old Mar 2, 2008 | 04:05 PM
Mike124's Avatar
Will these work.</span><br style="font-family: Arial,Helvetica,sans-serif;"></font>
SummitRacing.com
Summit 185 Series Wheels
Part Number: SUM-185-5883B
Rim Diameter (in): 15 in.
Rim Width (in): 8.00 in.
Backspacing (in): 3.750 in.
Offset (mm): -19.00mm
Center Bore Diameter (in): 4.250 in.
Load Rating (lbs): 2,200 lbs.
Mike
Old Mar 2, 2008 | 05:53 PM
They should work. They are the same back space and offset as the ones I just bought US Wheel 94 Series. I had to trim my fenders though since I have smaller wheel wells and went to 32" tires. Those wheels would stick out farther but with 30" tires I dont think it would be a problem.
Old Mar 3, 2008 | 01:08 PM
Mike124's Avatar
urchinTracker();</>Thanks for the help Dave, i'll put my order in an maybe now i drive around in 2wd when it snows or off-road.
Mike
Amsiraha
May 10, 2012 04:18 AM
tathanhthientu
Feb 5, 2011 07:30 PM
CowboyErik
Feb 6, 2008 12:35 PM
