Spark Plugs
Old Feb 4, 2008 | 08:39 AM
jlbovo's Avatar
i'm looking to repalce my spark plugs. Does any one here at the forum have a type of plug the can recommend ?! Thansk for your info !
-justin
Old Feb 4, 2008 | 08:11 PM
Depends on what year yours is. If it has ion sensing (started in '00 or '01) then you will need specific plugs. I prefer Denso brand plugs myself. I have Denso double platinums in mine.
Old Feb 6, 2008 | 01:48 PM
jlbovo's Avatar
mine is actully 1994. does it really matter then since it is so old. i've never changed spark plugs before , i noticed that some of them seem to be in a hard to reach places. is there some more infomation you should give me...like do i need to gap my plugs. i heard they come pre-gapped when you buy them specific to your mark/model.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Old Feb 6, 2008 | 10:08 PM
You could just use regular plugs on yours, doesnt have the ion sensing system. I usually check the gap but normally is where it needs to be already. Changing them isnt too bad, the hardest is #6 cuz the brake booster is in the way. I used a couple extensions and a swivel. They might be tough to get out. If so, start with a cold engine then run it for a minute or so to heat up the aluminum head which will expand the hole a little. Put anti seize on the threads of the new ones to prevent them from sticking in the future.
passport105
Feb 16, 2009 11:16 AM
Frank_1175
Aug 14, 2008 11:22 PM
justinporebski
May 14, 2008 01:28 PM
SamG
Jan 8, 2008 02:03 PM
shawntmartin
Nov 16, 2007 06:04 PM
