Spark Plug Removal??????
Old Aug 3, 2007 | 11:40 AM
IsuzuKid's Avatar
I have no clue on how to remove my spark plugs from my 96 rodeo 3.2 L i need help!!!!!!!!!
Old Aug 3, 2007 | 09:20 PM
Does yours have individual coil packs on each plug or does it have wires to the plugs?
Old Aug 4, 2007 | 08:49 AM
IsuzuKid's Avatar
it has coil packs and i don't even know where they are or what they look like.
Old Aug 4, 2007 | 04:50 PM
If yours has coil on plug you will have a coil over each spark plug. In the pic below the 3 'boxes' at the bottom of the pic on the valve cover are the coil packs. The other side of the engine will be the same way.
Two screws hold each coil pack on. Remove them and pull the coil pack off. The rubber boots can stick to the plugs and be really difficult to remove without tearing them. Some patience and possibly some penetrating oil can free them up usually. Do one coil and plug at a time so you dont mix up the coils.
Once the coil is off its a matter of using a spark plug socket, extension, and ratchet to remove the old plug and put in the new one. Take care when putting the new one in. The heads are aluminum and can strip easily if you over torque them. I also use some anti seize on the threads to keep them from sticking the next time I need to take them out.
Old Aug 4, 2007 | 08:00 PM
IsuzuKid's Avatar
Thanks that is exactly what i needed to kno and if you happen to kno anything about A/C mine just stopped working but before that it only worked on levels 3 and 4 what would you recommend
Old Aug 4, 2007 | 08:32 PM
If its just the blower not working but the ac compressor still works the common problem is the blower motor resistor pack. Not unusual for those to burn out. Its mounted to the side of the evaporator coil box. Remove the glove box and you should see it right there. I've never replaced one so cant tell you exactly what it looks like.
Old Aug 5, 2007 | 10:09 AM
IsuzuKid's Avatar
i saw your picture of your car where did you get your ram bar and smoked out lights
Old Aug 5, 2007 | 12:52 PM
  #8
I got both off ebay. The brush guard was from someplace with an ebay store so it was new. Cost $189 shipped which is the cheapest I ever found. Had to buy new mounting bolts though, the ones that came with it were too small and weak for me. I upgraded to 1/2" grade 8 bolts. The headlight/taillight blackouts I got used for $10 for the set plus shipping. A little scratched up but not a big deal. JC Whitney sells them for $65 a pair.
Waylander
Apr 9, 2020 02:39 AM
dutchie
Aug 22, 2007 07:17 PM
Kinnie
Jun 30, 2007 10:02 PM
Sparkplugs.com
Dec 1, 2006 03:39 PM
joewildlife12
Dec 6, 2005 07:55 PM
