slow battery drain
Old Oct 6, 2009 | 02:28 PM
Duster117's Avatar
Default slow battery drain
i have a 95 rodeo. i took it to auto zone and they said the battery was good but the alt was only putting out 42amps this IS charging the battery but after a day of sitting it has to have a jump to get going after that it will start right up. until i let it sit for more than 12 hours or so
any ideas
Old Oct 6, 2009 | 05:42 PM
kdfvwman's Avatar
Disconnect the negative battery cable @ the battery,
connect a DC Voltmeter between the negative post of the battery
and the disconnected cable.
If it shows 12 V then there is a load which causes the battery drain.
remove one fuse at a time and see which circuit is draining the battery!
When the Voltmeter shows Zero Volts, you have identified the drain, repair as needed !
Old Oct 8, 2009 | 10:13 AM
Duster117's Avatar
but isnt there the radio that always has a load caus of the clock
and the ecm memory?
Old Oct 14, 2009 | 02:04 PM
Duster117's Avatar
it was the battery!!
Old Oct 22, 2009 | 06:13 AM
lovely09's Avatar
I suggest check the battery again.Based on what you said,i think the battery has something to do with this issue.
Old Dec 3, 2009 | 05:09 PM
ROADMONARCH's Avatar
My Bro in law was original owner & he could not figure it out.
On My 93 ROD, same problem, changed out the ALT problem gone & Battery is good
Regards,
ROADMONARCH
funguseater
May 18, 2014 07:10 PM
themookman
Jan 19, 2010 01:23 PM
Blaised91
Sep 16, 2008 10:48 AM
neo_isuzu
Aug 16, 2008 05:45 AM
devildawg00311
May 16, 2006 03:58 PM
