Rodeo Starts fine but idles low under loa
Old Feb 23, 2008 | 06:22 PM
kerry howard's Avatar
All
I have a 2001 Isuzu Rodeo LS V6 4wd. The Engine Starts up fine and revs out good,but when I place the Transmission in drive or reverse the idle drop to around 0-200 rpm. I have also notice this happen when I turn on the rear defogger. The Check Engine and Check Trans Lights are on, but I get no codes from the ECU. I tested the alternator by disconnecting the battery and the roof light flickers is this the source of my problem. I do not want to start throwing parts at it. Could it be a broken wire?
all suggestions are welcome.
Thanks
_uacct = "UA-939292-44";
Old Feb 25, 2008 | 03:14 AM
Also found out tonight while topping up the transmission fuid that the right muffuler was cold to touch even though the engine was running. further diag revealed that the right side of the engine does not fire the coils. What voltages should i be checking for at the coil harness, I believe I have a broken wire since i repaied the vehicle after a crash.
Old Feb 25, 2008 | 05:52 PM
I traced back the three coil wires to the ecu and they all make contact to the ecu. Could mu ecu be bad. My number on the ecu are
8093561590
09356159
3.2L Aut Aus
can i use a US ecu with cal emissions
Old Mar 8, 2008 | 04:48 PM
The problem was the timimg on the left cylinder head it was out you have to rotate an additional 90 degress for perfect timing other than that it shut down the right side of the enginge because the cam shaft sensor does not sense the position to fire
Old Mar 9, 2008 | 02:37 PM
Good job finding the problem. I would have guessed alternator or broken wire to the ecu.
brianvn99
Aug 22, 2021 01:41 PM
Danharden
Sep 20, 2011 11:21 AM
Thelubeguy
Jan 23, 2009 11:49 PM
drvinsk
Axiom
Jan 10, 2009 07:32 PM
slipstick
Oct 24, 2008 12:11 PM
