Remove Fuel Pressure Limiter Valve (4JJ1)
![Default](/forum/images/icons/icon1.gif)
Quick query re the 4JJ1 engine in a 2007 Rodeo - I need to pull the fuel pressure limiter valve off but it's been fixed on very tight. Couldn't get it to budge even with a breaker bar. Anyone with experience that would advise for/against using a rattle gun to remove this valve? Common rail is still attached to the engine so I'm a bit nervous about applying force that could potentially damage the common rail itself.
