REcently bought a RODEO AND I NEED SOME HELP!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 10, 2009 | 02:07 PM
2002izuzu's Avatar
Default REcently bought a RODEO AND I NEED SOME HELP!!!!!!!!!!!!!!!!!!!!!!!!
can anyone help me i got a problom with 2002 rodeo i bought it is a 3.2 v6 automatic. i bought it with tranny leak one of the lines were leaking now i fixed that and i added fluid to the tranny while it was in neutral with truck idling. it took roughly 8 litres.
although the truck will only move in L gear and reverse. D 3 2 will not work. as soon as you put it in drive D the tranny goes right in to neutral. the truck goes into L and Reverse no problem it just wont shift up.
everytime i start it the check tranny light comes on and a/t temp also comes on ... even though the engine is cold i don't understand that at all? im also pulling up a po753 code. you think maybe tranny needs to be chages or is it something stupid? i like the truck is just this really ticks me off is that i can't even drive it out of my drive way. any help would be appreciated. would changing the filter help?
Old Aug 18, 2009 | 06:42 AM
Almasih's Avatar
I will need more info for diagnosis. When you put the gear in D, does the light on the dash show and stay in D or it moves around? Disconnect the negative on the battery for a while and reconnect to reset and try it. Check the transmission range switch on the driver side of the trans casing. It might need adjusting or the contacts need cleaning.
AKanadian47
Mar 31, 2011 01:18 AM
Tyrusaurus
Feb 19, 2011 10:36 PM
rberrido
Mar 18, 2006 08:34 PM
95rodeo
Jul 1, 2005 11:45 AM
95rodeo
Jun 1, 2005 02:45 AM
