Rear Speed Sensor(ABS Light)
I have been fighting the ABS light on a 98 Rodeo for the past week. I had it checked out, and the code said rear speed sensor short. I replaced the Rear Speed Sensor, but no luck. I checked the led going to the sensor and got 0 volts. I then checked both front sensors and they were reading 14 volts.
Has anyone experienced this or ever gone through troubleshooting the wiring diagram? I'm about to remove the bulb in the dash and call it quits.
