Newby here need help
Old Aug 11, 2012 | 04:31 PM
jake0383's Avatar
Default Newby here need help
I have been a mechanic in USMC for 20 years, just bought a 96 rodeo for $500.00, body and interior is perfect, with lots of valve noise, just changed 24 lifters, the old lifters had no sponge, locked solid, bought new lifters still rattle what can i do??????????
Old Aug 20, 2012 | 09:11 AM
randomorbit3's Avatar
Replace the cylinder heads. If lifters had more that .001" of clearance then it is out of tolerance, oil peed ports to the injectors could be partially clogged. You did not mention your oil pressure as if that is low it will cause clatter as well. Did you check the rocker arms for wear??
Hope this helps.
ventura73
Feb 1, 2012 08:53 AM
soloridr
Private 'Wanted' Classifieds
Mar 18, 2011 11:15 AM
trooper90
Dec 1, 2006 04:49 PM
chuckie
Pickup
4
Dec 28, 2005 09:49 PM
98ZuZu
Apr 12, 2005 10:01 PM
