My clutch went down to the floor
Old Apr 27, 2009 | 12:34 PM
security11122's Avatar
Default My clutch went down to the floor
I have a 1998 Rodeo with 197,000 miles and the clutch has been feeling a bit soft. I could still shift with no problems but would have too bring the paddle up with my foot. This morning it was all the way on the floor with no pressure at all. What happened. The fluid was low the other day and i refilled it but the pressure didn't come back up. The only other time it did this was when it was very cold 19 degrees, a few months back. I just took it as extreme weather. I don't see any leaks.
Old May 2, 2009 | 06:38 PM
ElectroGhandi's Avatar
You probably need a new clutch, haha.
Old May 3, 2009 | 08:39 AM
Default Hopeing it was just air in the line
I took it to the mechanic last week hopeing it was just air in the line. but he said the slave cylinder and master was bad. two hrs, later and $300 dollars less in my pocket, It runs great again. I don't complain because of the milage on the truck. I just started using it for towing a 3,000 lb. trailer.
My friend needs a clutch in his 95 model but he is so hard on it when driving. He is use to a Ford clutch which is a lot heavier. I have seen prices over $300 for a clutch and plate, not including labor. I am not looking forward to that considering how heavy the box is.
Old May 3, 2009 | 09:27 AM
Haha good thing you didn't listen to me then I usually hang out at standardshift.com (a manual transmission forum) and they replace their clutches all the time, so I just figured that was the issue.
Old May 4, 2009 | 10:12 AM
No problem, I do have a question i find that i don't have to engage the clutch until below 500 rpms and i come to at corner depending on speed take it in 2nd or 3rd gear. I can come to almost a complete stop in 2nd gear with no clutch, without the truck shaking or any protest from the engine. Is this normal?
Old May 4, 2009 | 02:03 PM
I've heard that if you have the car in a higher gear and you can come to a stop without it stalling, your clutch may need to be replaced. I can't definitively say whether you clutch is starting to get worn, however.
Here is another test to see if you clutch is in need of replacement--
Originally Posted by StandardShift.com
1. Get moving and put the car in 3rd gear or higher and low rpms, where you normally do not have enough power to accelerate quickly. Floor the gas. If the revs shoot up but the car doesn't go, you need a new clutch. If the engine bogs and the revs raise relative to the car's acceleration, your clutch is fine.
Old May 18, 2009 | 07:06 AM
povar's Avatar
Agree with you, man
Old May 19, 2009 | 07:13 AM
  #8
Default Miles on your clutch
What the highest millage u seen on a man clutch? I have heard 200,000 miles but that seems hard to believe.
bigbean94
Jan 23, 2012 04:29 PM
earlIsebella
Nov 19, 2008 03:55 PM
earlIsebella
Nov 18, 2008 10:43 AM
jstar41
Nov 11, 2008 11:12 PM
XtremeAaron
Nov 16, 2006 12:38 AM
